Finally, a poster points out that a magneto has a distributor same as battery ignition unit on these multi cyl engines. One other thing to consider about difference between the two is that the mag starts on a retarded spark through the impulse mechanism and as soon as that disengages you are on full adavance at all engine speeds. Most H-4 mags run at about 30 degrees advance. I personally feel the engine is better served with a properly operating advance in a battery ign unit.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
