Re: CARB ADJUSTMENTS
Posted by old on March 03, 2009 at 11:17:19 from (4.245.3.245):
In Reply to: CARB ADJUSTMENTS posted by JON ARCHAMBAULT on March 03, 2009 at 10:19:56:
Do not run it with gas in the oil or you will be looking at an engine rebuild soon. Do you shut off the gas when its parked?? If you don't you need to. Float may not be set as it should be and will cause that but even if the float is set right it is common for gas to get in the oil if you don't shut it off when parked
