Magnetos are not mysterious nor difficult to maintain. They are “mysterious” only because there are not a lot of people out there who truly understand ‘em. And if a mag is kept clean and dry it will generally require LESS frequent maintenance than a distributor.
A big advantage of magneto is your tractor will still run without a battery, generator, etc. – the magneto is completely independent, self-contained ignition. (All you need is a good arm - or a short pull - and your tractor will go.)
However as ADLM points out in his post, magnetos have only two automatic timing settings: crank and run. A distributor OTOH has a centrifugal advance which automatically adjusts the timing in over a range of RPMs. Means that a distributor-equipped tractor may use slightly less fuel under certain speed/load conditions. Also a distributor generally can be timed so the engine can idle smoothly at lower RPM than with a mag, yet will permit the engine to develop maximum power at governed RPM.
Were the tractor mine and it was originally equipped with a magneto, I’d leave it that way!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
