Re: 240 utility questions
Posted by Coax on March 03, 2009 at 12:29:11 from (173.116.92.37):
In Reply to: 240 utility questions posted by a.c._hd6g on March 02, 2009 at 19:56:19:
I've got a '58, w/a Davis loader,a separate nose Pump and its done everything i"ve asked of it.(including pulling a few stumps I might add) It also has a factory Fast hitch it is 3pt used w/a splitter,auger and I built forks on the back(3pt) to move 6 ft logs..works like champ.!!!!!!!!
