Re: Farmall C Hydraulic pump Seal
Posted by Idaho Ron on March 03, 2009 at 15:21:08 from (208.98.173.2):
In Reply to: Farmall C Hydraulic pump Seal posted by farmallmechanic05 on March 03, 2009 at 10:00:17:
There are a few pumps that can fit on it. The pump on mine is a Wooster pump off of a farmall 130. My wooster rebuild kit had instructions in it, and were easy to follow. The first step is to take off the pump. You will need to remove the hydraulic lines, then there are 4 bolts on the pump. Only 2 of the bolts hold the pump to the motor, The ones you need to take off I think are the top left and the bottom right. After you get it off then take the pump to IHC and they will find a rebuild kit. When you take it appart check the shaft. If it has ANY sign that there is ware on the shaft use a speedy sleeve to fix the worn spot. On my wooster I elected to have a machine shop press my front seal in. In all it is a easy rebuild. Ron
third party image
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
