Re: 1959 IH 460 diesel questions
Posted by DWF on March 03, 2009 at 16:56:00 from (74.36.10.61):
In Reply to: 1959 IH 460 diesel questions posted by GoJDpuller on March 02, 2009 at 18:00:38:
I recently bought a small Galion Grader which had a UD 236 engine, same as 460D only a little newer. They had had a lot of trouble starting it and it didn't run very well at all. First thing I found out is the injectors were in wrong. They had the glow plug on the bottom, below the fuel line. I found out on this site that that makes a difference in starting. It had been this way for a very long time as it had been painted a long time ago and you could tell the injectors had not been removed after the painting. The starter has to be in good condition to spin the engine fast. When I took the injectors out, 4 of the 6 were leaking. I purchased new glow plugs, rebuilt injectors from Central Fuel Injection, a rebuilt starter and new wiring. Starts and runs perfect now although it is a cold blooded engine.
DWF
