Farmall SM rearend getting warm??
Posted by HSE on March 03, 2009 at 19:45:36 from (68.238.14.181):
I was plowing about 10 acres with my SM last fall. When I was finished a notice that the lower rearend housing was definitely warm and uncomfortable to touch. The transmission is full with 85-140 gear oil. The tranmission makes no strange noises. The brakes are not dragging. Any ideas if I should pull top cover and look for a bad bearing or is this normal. I have only played with this vintage of tractor, not really ever worked one in the field before. Thanks for any help!
