Since the carb is a down draft they are more sucesseptable to heat soaking from the manifold which can boil the gas in the bowl and cause it to spill into the carb throat. One thing you might try is to set the float just a tad lower. One thing I do on my F-12 is turn the gas off while it is running and let it run for a min or so then shut tractor down. Seems to help too.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
