Posted by Owen Aaland on March 03, 2009 at 23:22:39 from (65.165.246.54):
In Reply to: Farmall560 Hydraulics posted by David Kinnison on March 03, 2009 at 05:01:08:
Like Scott says.
The 560 uses a closed center hydraulic system with a constant displacement pump. There is an unloader valve that has to move to dump oil to the reservoir when there is no demand for hydraulics. The unloader valve also functions as the system relief valve. The flow of oil through the orifice is what controls the unloader valve. If it gets plugged or the screen so dirty that it does not allow enough oil through the system will stay on high pressure. Excessive wear in the auxiliary valve spool and body can also keep the system on high pressure. Check the orifice first.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
