Re: Re: Re: Re: Re: Re: Plows for Farmall M
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Bob M on April 08, 2000 at 07:00:00 from (171.212.108.154):
In Reply to: Re: Re: Re: Re: Re: Plows for Farmall M posted by Farmer Bob on April 07, 2000 at 22:24:19:
FB - You mentioned the only thing missing is GPS antenna. Actually that tractor DOES have GPS!
I was using a GPS receiver (Magellan Colortrak) when that photo was taken. Was chisel plowing a piece that's about 1-1/2 miles long. Used the GPS to mark a waypoint whenever the rig pulled up a rock too big for me to lift into the rock rack. When done plowing, I use the GPS to create a route connecting each rock's waypoint, and a GOTO to the first rock in the route. Then when we come back with the rockpicker, the GPS "navigates" a route from rock to rock thru the field. Found the GPS will generally steer you within 100 ft or so of each rock - near enough to zero in by sight.
Cool technology!
Bob
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Plows for Farmall M
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
