Most kerosene-distillate tractors were in the 4 to 1 ratio range. Any higher, and they knocked like crazy if burning those fuels. The specific ratio may be available somewhere, although I don't think I've ever run across it. One thing that occurs to me is that, even if you don't come up with an exact ratio, a fairly-uniform pressure across the four cylinders would suggest that things are ok. One thing that was sometimes done to these tractors was to put in higher-compression pistons (which were available, I believe, as "high-altitude" pistons). This would have been done to allow using gasoline exclusively. There is always the possibility that this has been done at some time in the life of this tractor.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
