Re: New Farmall M
Posted by mkirsch on March 04, 2009 at 10:01:30 from (64.80.108.57):
In Reply to: New Farmall M posted by CNKS on March 04, 2009 at 07:23:19:
Between a decent gearbox and paper pulley, you'll probably put about $200 into the project. Easy parts to find.
Tires, another $1000-$1200. New tires are big $$$, and good used ones are scarce as hen's teeth.
Given that the belly pump is empty, you've got to assume that it needs work. Hopefully the previous owner removed the drive dog so the pump didn't run empty and totally destroy itself. Maybe there's a little oil left in the bottom of the reservior that's keeping the pump lubed. Figure on taking it out and fixing it regardless.
