Posted by Rudi on March 04, 2009 at 11:23:56 from (99.252.48.17):
In Reply to: Cub questions posted by Karl Hamson on March 04, 2009 at 05:40:26:
Chief 83 said: (quoted from post at 06:40:26 03/04/09) Crank should be back tomorrow. Bearings, rings and gaskets are ordered. Replacement head should come in by the end of the week. I'm getting closer to going back together. I'm deeper into this than planned ($) so while I don't want to miss anything crucial I don't want to break the bank. The head is used. Does it have to be milled or is it likely to be ok? The clutch disc looks pretty good. Does anyone know how thick a new one would be? If it's close I would like to reuse this one. What else should I do now that I'll be sorry I didn't do later as long as I am this deep into the motor? I'm sure I will have lots more question upon re-assembly. Thanks
CVhief:
I just put on a new to me head.. used. Checked it on my bench with a good steel straight edge. Looked good, went on after it was wire wheeled and cleaned up. It does NOT require milling in most cases. These heads do not require the tolerances of many newer engines, the C-60 is a forgiving mill. As long as there is no obvious twists, cups or dish to it, it should be ok. Remember to use a new head gasket, new head bolts.. they are available at any good fastener supplier, use C5A or Kopper Kote on the threads and maybe High Tack on the gasket itself.
For the clutch information and other info from the service manuals, check my Cub Manual Server Also, it is important that you torque the head according to the directions in the GSS-1411. Failure to do so WILL result in a cracked head.. I know.. been there done that... Check out the Clutch specs also.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
