Re: MORE 985 TRANMISSION QUESTIONS
Posted by DMont on March 04, 2009 at 13:36:50 from (72.9.65.174):
In Reply to: MORE 985 TRANMISSION QUESTIONS posted by chris meredith on March 03, 2009 at 16:45:32:
The only way to really tell is to look for teeth in the trct rear frame and/or pull the cover plate to the range trans. You will need to jack the cab up to actually get it out. I know its a bear because I just finished one. I'm not sure you can get a prybar to the pinion shaft thru the left side cover plate. The counter shaft is right in the way.
