Re: 47' Cub Rearend Followup
Posted by Bigdog on March 05, 2009 at 10:26:08 from (71.64.18.18):
In Reply to: 47' Cub Rearend Followup posted by Standard U on March 05, 2009 at 09:12:58:
This is easier to do if you remove the final drive first and do it on the bench. The threads on the nut are right hand. Just hold the axle and back the nut off. It should not be real tight. The axle runs through the bull gear and there are shims and spacers in there. Remove the bottom pan to see what you have. Once the nut is off you can press the axle out.
