Re: Farmall Bolster end play
Posted by Bob M on March 05, 2009 at 10:51:33 from (151.190.254.108):
In Reply to: Farmall Bolster end play posted by david g on March 05, 2009 at 10:11:55:
David - I don't know how much vertical play is "correct" for an H. However the pivot shafts on both my Super H and Super M drop between 3/8" and 1/2" when jacked up.
There is no adjustment for end play . However excessive end play can be from a failed (crushed) pivot shaft thrust bearing, a loose or improperly installed worm sector gear, or a missing thrust bearing spacer.
With the tractor is resting on it's front wheels, so long as the 4 bolts that connect the pivot shaft flange to the front wheel bolster flange do not rub on the underside of the fixed bolster, the worm sector gear is reasonably centered vertically with the steering worm, and the steering is not too stiff overall, I wouldn't worry about the amount of end play.
