Re: More Belly Pump Questions
Posted by wayne in mn on March 05, 2009 at 15:07:48 from (66.188.166.75):
In Reply to: More Belly Pump Questions posted by cessnapilot3@gmail.com on March 05, 2009 at 14:52:13:
Belly pumps are not very complicated. I suspect the casting that the outlet pipes are fastened into may be cracked, one of the pipes may be cracked, or the gasket is damaged.
Try removing each pipe & inspect them. If you have to remove the pump, the pipes must be removed anyhow.
