Re: Over run coupler
Posted by Dave S. on March 06, 2009 at 06:23:28 from (208.92.171.224):
In Reply to: Over run coupler posted by Charlie Sisk on March 06, 2009 at 05:49:56:
I have used the cheaper clutch bought at TSC and held on the pto with a spring pin. These have a tendency to break the spring pin and allow the shaft to slide off of the tractor pto. My neighbor had this happen and broke the input shaft off of the gearbox on his brushog.
For two years I have been using a over running clutch bought from Agri Supply with good results. It has the push pin to attach it to the pto on tractor. Here is the website and item #
www.agrisupply.com Item #71429
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
