Agreed. The older gas engines from the 1950s run with very low compression ratios. 87 octane will cover their needs without knock or excessive heat easily. As pointed out by Gary current octane ratings would have measured several points higher back in the 1950s and 1960s.
If you are getting engine knock with 87 octane on a engine with less that 8.5:1 compression ratio you have a problem - and it sure **** aint the fuel. Its only when you get up to 9:4 or higher that octane becomes an issue (with pump fuel) - and usually only with mechanical variable ignition timing.
The Super H in 1952 only had a compression ratio of 6.1:1 and the Farmall 450 only had 7:1 compression ratio - well within the operating range of current 87 octane fuel. Running 91 octane fuel in them is a waste of money.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
