No problem with controller, it is your thumb like Hugh said. However, when using a charger the voltage can get very high when using high charge rate like boost. I have seen many glow plugs blown with a charger, and might add that normal 14.5 volts of the charging system may blow them sometimes also. If you let go of the glow plugs after it is running and the voltage comes up to that normal range and then reapply the glow plugs you are taxing them to their limit. If I wanted to clean an engine exhaust up in that situation I always throttle way down , maybe even put lights on , then press glow plugs again and speed engine back up to where you want it. . If you have to use the boost to get it started, with charger off, hit starter for a few seconds, hold glow plugs proper time , hit starter and now turn on the boost and quickly shut off charger when she fires up that way voltage will stay in range.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
