Re: piston clean up
Posted by Janicholson on March 06, 2009 at 10:46:38 from (199.17.6.136):
In Reply to: piston clean up posted by Chief 83 on March 06, 2009 at 10:43:01:
Steel wool yes, no sanding. Some carb cleaner will help. clean the grooves well with a broken ring! JimN
