Re: piston clean up
Posted by GordoSD on March 06, 2009 at 13:22:30 from (66.115.200.140):
In Reply to: piston clean up posted by Chief 83 on March 06, 2009 at 10:43:01:
I'drop the pistons in the cylinders without the rings and measure the gap at at least 8 points. See if they are within tolerance.
If they are aluminum pistons DON'T use steel wool .Small particles of steel will work into aluminum. Fine to use 220 grit sandpaper. One of my high school jobs was in amachine shop knurling pistone. They were really rough when you finished that but you could make a piston about 015 larger by doing that.
Gordo
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
