Re: Farmall C oil leak
Posted by Red Dave on March 06, 2009 at 16:48:12 from (98.235.23.26):
In Reply to: Farmall C oil leak posted by ih460 on March 06, 2009 at 16:18:21:
Could be the rear main, or maybe the plug at the rear end of the cam.
Either way, you have to split it and pull the flywheel. Can't get at either one any other way.
Before you go to all that work, check the oil level to make sure it isn't too high, like the Cowman said below. It may not be that, but it is surely a lot less work to try.
