Posted by Owen Aaland on March 06, 2009 at 23:36:17 from (65.165.246.54):
In Reply to: More Belly Pump Questions posted by cessnapilot3@gmail.com on March 05, 2009 at 14:52:13:
It is highly unlikely to be the gasket. The gasket only seals the pump assembly to the reservoir. There is no place where the gasket is subjected to pressure so it should leak the same whether or not the pump is under pressure.
If it leaks from the center it is most likely the seal. If it comes down from the side it is most likely a cracked pipe where it threads into the pump assembly.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
