Re: Farmall 706 - Good Price? What should I worry about?
Posted by IH fan on March 07, 2009 at 06:09:35 from (208.189.38.84):
In Reply to: Farmall 706 - Good Price? What should I worry about? posted by Nathan in Texas on March 06, 2009 at 19:56:18:
If you already have a 12' disc, you should be able to pull it easily with a 50 hp tractor, so that might expand your search.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
