Re: 12V Gen on H
Posted by RN on April 13, 2009 at 11:12:12 from (96.60.82.165):
In Reply to: 12V Gen on H posted by henryvxx on April 13, 2009 at 10:48:10:
old 6 volt regulator on 12 volt generator? not a good thing to do. What kind of generator are you using? Small Ford, VW, or something else? Old mechanical regulators were a break circuit with points , controled output more on amperage than voltage- so old regulator still breaking same amount of time but the double voltage is letting more wattage to battery for about same amount of amperage= overcharged battery. Try to match regulator to generator voltage or see if can adjust old one- many older designs were servicable and adjustable. RN
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
