Re: Oil for A
Posted by ScottyHOMEy on April 13, 2009 at 21:08:07 from (70.105.240.241):
In Reply to: Oil for A posted by 1939 Farmall A on April 13, 2009 at 17:14:09:
If it's a brand spankin' new rebuild, I like to run a straight 30 with detergent until the rings seat. After that, Mark has it nailed. Any reputable brand multi-weight of at least 10 on the thin end will serve you just fine. Some guys run the 15-40 oils made for diesels. Only thing I'd stay away from is the 5-XX stuff -- it's made for motors with a lot tighter clearances than your A, and the oil film is a critical part of your bearing surface.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
