Posted by the tractor vet on April 14, 2009 at 07:02:27 from (76.212.233.212):
In Reply to: Re: pto problems posted by davin003 on April 13, 2009 at 19:53:59:
Well , I told ya all that i can as there is not much to them units so if everything is as it should be and the pick up tube is snug in the clamp the tube does not have a flat spot and in the correct position and does not flop around as this will cause the seal to suck air as it just sorta sets in the bore and the pump is good ya got the valve put back together correctly don't know what else to tell ya as like i said i CAN'T see it. It takes me about two hours from the time i start with draining the oil to the time it is running in the tractor again. Did ya check the brake piston's ? last thing as to where the oil pressure could get dumped . Oh if your going to replace the teflon seal rings on the clutch drum it helps if ya soak them in hot water - oil to warm them up then use a piston ring compressor to shrink them back into the seal ring groves . and be care full when reinstalling the clutch drum back into the housing so not to damage the seals . I use white grease on theses .
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
