Re: Installing a cab heater on our 706.
Posted by MN Scott on April 14, 2009 at 10:28:08 from (206.9.216.89):
In Reply to: Installing a cab heater on our 706. posted by Lou from Wis on April 14, 2009 at 07:47:22:
Run your pressure from the block drain or T into the temp sensor port. Return the water to the bottom radiator drain. You will need to replace the drain valve with a hose fitting.
