If your water pump has a port on the right side you can sometimes use a street elbow and and run the heater return hose down away from the exhaust manifold. I have also seen a hose nipple installed in the lower radiator hose. Another choice is to return the flow to the radiator drain. Using the block drain will only give you thermosyphon flow through the heater core.
The heater inlet hose should be connected with a tee in the temperature gauge hole in the head.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
