Case IH has a web site. If you follow the links to parts, you can bring up 200 Farmall. Every part is listed at some place on the parts diagram and you will be able to establish original parts numbers. The rear end and trans fluid add hole is on top of the deck just to the front left of the gear stick. The level check is a plug at the right rear of the axel housing. Make sure the tractor is sitting level when you make the check. Hydraulic oil is to be checked by removing the fill plug on the left of the hydraulic reservoir under the gas tank. Fill with hydraulic oil until it runs out. The level changes depending on the touch control and rear remote cylinder settings, so the level may change.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
