140 Smoked another birdnest
Posted by NawlensGator on April 14, 2009 at 13:00:20 from (52.129.12.50):
Thought someone nearby was burnning trash while mowing with a 140. When I looked around I saw fire and smoke comming from under the hood and knew immediately the damned wrens had built a nest on my exhaust manifold again. The fan was fanning the flames. I shut it down, jumped off, and let it smolder out. Took about 5 min and then I finished mowing.
This is not the first time, and I have learned to always check and remove their nests before cranking. This time I forgot. Pretty exciting seeing a fire burn under the gas tank and beside the fuel lines and carb. Hope I can remember to check next time.
