Keep the rpms down if it is a stock cam ! On a dyno a stock cam runs out of lift around 1900 rpm, meaning the torque #s fall off fast.
If you need more get a stiffer governor spring and be prepared to turn the rpm back down to normal levels. A stiffer spring will help hold the governor back , so you will notice a differance. But operate it in the 1800 rpm range.
The spring must be the exact same length "no longer". You will find one at your local hardware store or Tractor supply. Take yours with you and compare "bigger diameter coil ".
They come in a yellow and white bag and there is "2" in each package.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
