Re: Farmall H lift all
Posted by Janicholson on April 14, 2009 at 18:13:47 from (66.173.50.100):
In Reply to: Farmall H lift all posted by David G on April 14, 2009 at 18:09:29:
Easiest is to put a lump of metal on the bottom side of the pull rod to hook it in the on position. This allows it to be shut off from the circuit if needed, and still be pretty stock. An internal tab could be made to hold it in the on position at the control, but I think that would be less control, and flexibility in use. It might confuse the next owner as well. JimN
