Re: Plow in a pickup bed
Posted by Hugh MacKay on April 15, 2009 at 09:01:30 from (209.226.247.61):
In Reply to: Plow in a pickup bed posted by mkirsch on April 15, 2009 at 05:55:21:
MKirsch: Your going to reduce it to 2 bottom anyhow, why not do it on the spot then the 2x14 plow will fit in your pickup.
Another option, front wheels are narrow enough to fit between fender wells. Remove the tongue and load it front end forward. You'd still be better with bottom and tail wheel removed, put them up front. Mounted they will be a lot of weight out back, plus front tip of that 3rd bottom will be on your tail gate. Bottom and wheel off you should be able to close the tail gate.
