I don't know what the ambient temperature was when you did your test but it sounds fine. A thermostat usually does not seal off the coolant completely so some rise in temp at the top of the radiator is to be expected.
I have a C750 Ford with a 391 in it. Unlike the F series truck, this engine has the thermostat mounted in an adapter a little in front of the intake manifold. I once replaced the thermostat with a brand that did not have a bleed hole in it. When the engine was first started every day the coolant temperature would rise until it started to boil and then the thermostat would open and everything would be fine until the engine was left to cool completely. Then the process would be repeated. Without the bleed hole the thermostat, there was no coolant flow around it and it would not get warm enough to open until the steam reached it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
