Re: farmall h dripping anti freeze
Posted by Andrew Z on April 15, 2009 at 18:25:33 from (64.252.181.197):
In Reply to: farmall h dripping anti freeze posted by narrowfarm on April 15, 2009 at 18:16:43:
There is a complete pump packings/seal, its hard to explain with out a manual. You can rebuild it yourself if your up to it or order a re-manufactured one. however before that i would try a bottle of aluminum flake radiator sealer. My fathers Super H had a very slight weep from the water pump put that in and its been fine for over 2 years. That was a small leak though maybe a few drops or so a day.
Andrew
