Posted by DougIH on April 15, 2009 at 20:36:05 from (66.188.248.150):
Have a 3588 with issues. First, engine overheated last fall and then water was getting in the oil. Any chance this could be a head gasket or other simple fix, or are we looking at an overhaul? Also, we lost first gear. Any chance that this is a bent fork or linkage that needs adjusting? Read on this forum once that this is most likely a nut of some sort that comes loose. Also heard that this wears out the housing and quickly ruins the rest of the transmission. Is this true?
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in
... [Read Article]
Latest Ad:
[More Ads]
