When I was a "lad" back in the 40s, farmers sometimes complained that the H and M were not the equals of the F-20 and F-30 they were supposed to replace. I don't think it was so much a matter of actual horsepower, but of torque. The F-series had big engines, designed to run pretty slow. They had great torque, and would pull through even when overloaded. I remember trying to plow with an F-20 in FOURTH gear, and even though it would only get up to about 1/2 speed, it kept right on going. Don't fret, guys. I just did it for a coupla minutes--adolescent stuff. The H, especially, has a much smaller engine, designed to run faster. I used the same plow with two Hs, and they just didn't have the torque the old F-20 had. H of a lot nicer to drive (I guess that could be a joke, but it's probably not very funny). I never tried a 3-bottom with an M, but I think the complaint was around among farmers back then. An uncle of mine used an M in clayey soil and pulled only a 2-14 plow. I've spent some "quality time" with a Super M in the last few years, and I found it a really gutsy tractor for its size. I liked the higher speed in 4th gear, for travel on farm trails or pulling wagons on gravel roads, and I certainly liked the extra torque (partly from a larger engine than the regular M, and partly, I'd think, from a higher compression ratio). The original IHC hydraulic system on the M is pretty primitive. If the clutch is disengaged, you have no hydraulics. Independent hydraulics are really nice. I used to do a lot of "chore work" with the Hs (mowing around fences, bushhogging in tight places) and found them almost as easy to use as an F-12 that I had used before the Hs came along. The Super M is definitely NOT for one-finger maneuvering in tight places. Power steering would probably help a lot, but it is still a big, tall tractor. Delightful in an open field. Great sound, makes a little guy feel like he's flying a 747.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
