Re: farmall spark
Posted by old on April 16, 2009 at 11:46:11 from (4.245.3.106):
In Reply to: farmall spark posted by donald 1246 on April 16, 2009 at 10:33:02:
I would first start by cleaning and or replacing the points. See if you can get a spark at the points then go on to other things that might be causing you problems
