Re: farmall spark
Posted by Janicholson on April 16, 2009 at 11:48:53 from (199.17.6.128):
In Reply to: farmall spark posted by donald 1246 on April 16, 2009 at 10:33:02:
Most likely a new coil (points might also be needed. I assume you were running it while the coil was getting hot. It is not a good idea to leave the ign. on while not running, that will overheat the coil because it is designed to be "On" about 1/2 the time or less. Dwell as a percentage of rotation per cylinder.
JimN
