Re: Need an education on H Hydraulics
Posted by john *.?-!.* cub owner on April 15, 2009 at 20:12:59 from (75.121.0.129):
In Reply to: Need an education on H Hydraulics posted by DJL on April 15, 2009 at 19:27:43:
Live hydraulic system is one where the pump runs all the time engine is running, regardless of clutch position. On the earlier model H with the belly pump it runs off the transmission so the clutch must be up. All 3 connections are positive pressure. pull lever up and pressure is applied to all the connections commonly. move to middle and it will hold. push lever all the way forward (down) and the fluid will flow back through same fittings. To use remote valves the return will need to go back through the filler on top of unit.
