Re: Cub-Lo - NO oil pressure
Posted by El Toro on April 16, 2009 at 17:06:00 from (64.12.116.73):
In Reply to: Cub-Lo - NO oil pressure posted by RobertF on April 16, 2009 at 16:24:38:
To prime the pump! Hal
1.Remove the allenhead screw at the back left side of engine block and pump oil using a squirt can.
2. Remove oil filter cap & fill housing with engine oil & replace the top.
PS: Then start engine and let idle to see if you have oil pressure.
