Re: Farmall 200 carb leaking
Posted by tom burke on April 16, 2009 at 21:14:42 from (72.230.143.186):
In Reply to: Re: Farmall 200 carb leaking posted by RustyFarmall on April 12, 2009 at 18:53:11:
just went through the same thing. was told just about every thing you have had heard. at the base of the fuel bowl where the fuel is drawn out of the bowl not shure what it's called I think it's the venturie but this is how i found the problem. remove lower base fill bowl half way cover with duct tape very tought like making a diafram and press on it the problem will become aperant. when you press on tape if ya get fuel coming out of the tube in the middle of base the valve at the base is defective the carb needs enough air flow through it to draw fuel from the bowl and should not let it run out when just sitting there with fuel on
