Re: McCormick-Deering 10-20 runs but I can't hand crank star
Posted by mkirsch on April 17, 2009 at 18:32:03 from (64.80.108.55):
In Reply to: McCormick-Deering 10-20 runs but I can't hand crank start it posted by Dave Koenigsfeld on April 17, 2009 at 17:31:29:
I don't know much about hand crank starting, but it sounds like you're putting too much fuel in when you prime it. 3 tablespoons is an awful lot of fuel.
I may show my ignorance here but, does the carburetor have a choke? Rather than spooning fuel in, you might want to set the choke for a couple of pulls to prime the engine with a proper amount of atomized fuel that will fire off much more readily.
When I start the old chain saw, I set the choke and pull until it pops, then release the choke. It always starts and runs on the next pull. That might work for you here, as I've watched a few videos of people hand-starting tractors, and they do the same thing.
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on ... [Read Article]
