Posted by spiffy1 on April 17, 2009 at 20:11:47 from (70.41.137.72):
In Reply to: Hard-starting 15-30 posted by DAN DOYLE on April 17, 2009 at 19:21:39:
For the purpose of starting, it's easy to check the mag. If it's running rough etc, you need keener ears or better equipment than I to diagnose between condensor and coil break down, ect.
Put #1 (or any wire of the right length) wire on a spark plug and sit it on the oil cover. Engage the impulse [a '28, if original, I believe is E4A with manual impulse], and crank it over while watching the sparkplug.
Also, you can pull the 4 bolts from the bottom [note which # and wire {the wires may not be in the 'book' sequence} just fired so re-timing is easier] put two back in and stick in a vice for the easy viewing while you index it with the impulse engaged [if the impulse works you'll need a piece of barstock, a screwdriver or really strong wrists!].
If it's running good after pulling, I'm more inclined to think rings, valves, or carb. Oh, it will likely want a crank or two with choke first if you have the R style [if the exhaust is out the hood instead of side, you have an updated carb/manifold] carburator.
Finally, instead of pulling it why don't you throw a belt between the pulleys? Still a pain, but certainly safer!
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
