Actually, it shouldn't even need it since you've had it running recently, and you're running gas, so no worries about kerosene in the carb, but those carbs will want one or two half-cranks of choke, then no choke.
You have the original governor, if I remember your video correctly; if so the throttle lever controls the carb directly except at rated RPMs, so the throttle about half too is a good place to try.
Do you have the priming tubes closed? Even without the rings seated yet (I think you have new sleeves and rings, and the head reworked), I doubt this is your problem, but does it have suction [if you have good compression, barring a bad manifold gasket etc, you probably have suction]?
Else, maybe the carb is plugged, but these don't have really fancy orifices.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
