Re: McCormick-Deering 10-20 runs but I can't hand crank s...
Posted by willie in mn on April 18, 2009 at 04:41:41 from (205.188.116.73):
In Reply to: McCormick-Deering 10-20 runs but I can't hand crank start it posted by Dave Koenigsfeld on April 17, 2009 at 17:31:29:
Dave
IMHO, James has found most of the problem. The impulse pawl needs to catch & snap for each plug at cranking speed. A mag needs that quick spin when the impulse releases & lets the wound-up spring flip it over & generate the spark.
Also, in case it accidently tries to fire without the impulse delay, it will kick & tear your fingers off or break your arm quicker than you can say "oh shucky darn, wish I hadn't done that".
Get the impulse working first, them bettcha a dollar to a donut, she'll fire right up.
Side note- My Dad farmed with 10-20, 15-30, & regular. Had local "expert" set the timing, could spin each with right hand, never had one "kick".
HTH
Willie
