Posted by spiffy1 on April 18, 2009 at 08:58:13 from (70.41.137.72):
In Reply to: Hard-starting 15-30 posted by ScottyHOMEy on April 17, 2009 at 19:21:39:
No offense taken, only confused because with modern view [which I'm using] vs. classic view sometimes I think I misinterpret the reply trail.
If you have good compression, you should be able to rule out the rings and valves (which still could be set wrong if good cold and erratic hot, but doesn't sound like the case).
As just noted, you'll have to listen for the impulse (the E4A you can see and hear, but have make sure to manually trip it before cranking), it could be stuck; but if it's running rough it sure could be coil or condensor or points instead or as well as the impulse.
Today's Featured Article - Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
[More Ads]
