Re: McCormick-Deering 10-20 runs but I can't hand crank s...
Posted by Dave Koengisfeld on April 18, 2009 at 09:19:44 from (148.78.54.134):
In Reply to: Re: McCormick-Deering 10-20 runs but I can't hand crank s... posted by spiffy1 on April 18, 2009 at 08:38:13:
The murphy's law is exactly right. I have spun it a few time without the pawl in. You look down and just go shuuuucks.
The plugs are not wet but I will cut back on the fuel amount.
Next I am going to check the color of the spark on each cylinder and also check that the spark is firing at TDC of each cylinder.
What would be wrong with the impulse if I am getting good spark?
I can put a tougher spring on the pawl to see if that helps. It seems pop up and get out of the way if I get a good crank on it.
